Hi,
I've got these 2 files a mdf and a mds. I know I can burn these with alcohol 120% but tried many times and wasted many cdrs. Haven't succesfully burnt a cd with that. I normally use nero cos always got like 99,9% success rate.
I've tried to convert the mdf to iso with winiso and burn it but then my vcd player couldn't read the file (the mdf contains a couple of dat/mpeg) files). I think it needs the mds file too. I can play it on my pc but I need to play on my vcd too.
Does anybody know a solution to this problem?
I've searched everywhere but couldn't find an answer.
thank you very much
i think you are in the wrong topic!
However, i have no idea what you are talking about, so I dont even know where to move you to!
hopefully someone who speaks windows will wander in and set you straight! -
it is the wrong forum.. buuuut try this
download daemon tools, mount the mdf/mds & do a disc to disc copy on the fly throgh nero..
http://www.daemon-tools.cc/portal/portal.php -
Isn't mdf some wood ?, it would be bad to burn that
I didn't know where to go too and this is the place with lot of whizkid. So I thought some might know the answer.
But thankx for the link. -
Hey U can use DVD decrypter!!
That will workDoing it now with something else
Cheers
how to play mdf file
By jyeh74 in forum Newbie / General discussionsReplies: 5Last Post: 2nd May 2015, 10:01 -
How to burn a .iso/bin,cue with nero
By Chupes in forum User guidesReplies: 5Last Post: 9th Sep 2009, 20:33 -
ISO w/ .MDF file
By 3lutz3toe in forum MacReplies: 1Last Post: 5th Dec 2007, 14:22 -
HOW TO BURN Ps2 games MDF/MDS on MAC OSX
By kimkimkimmykim in forum MacReplies: 7Last Post: 2nd Nov 2007, 02:52 -
extracting vobs from mdf files
By uglijimus in forum Newbie / General discussionsReplies: 7Last Post: 15th Jun 2007, 13:15
