I tried to make a VCD with chapters every 5 mins but it still plays as one file? No chapters?
I did see that I had not put a tick in the "add empty SEGMENT dir". Did I need too?
Also do I need to do something in the Iso files menu?.
Below is the Log:
MarkInternally computed XML generated successfully as "C:\My Documents\Mi2\mi2.xml"
GNU VCDImager 0.7.10
initialising libvcd 0.7.10 [cygwin/i686]
this is the UNSTABLE development branch!
use only if you know what you are doing
see http://www.hvrlab.org/~hvr/vcdimager/ for more information
mpeg stream will be padded on the fly -- hope that's ok for you!
autopadding requires to insert additional 875980 zero bytes into MPEG stream (due to 43799 unaligned packets of 267253 total)
scanning mpeg sequence item #0 for scanpoints...
writing track 1 (ISO9660)...
writing file `CDI/CDI_IMAG.RTF' (1315168 bytes, raw sectors file)
writing file `CDI/CDI_TEXT.FNT' (13616 bytes)
writing file `CDI/CDI_VCD.APP' (102400 bytes)
writing file `CDI/CDI_VCD.CFG' (193 bytes)
writing track 2, MPEG1, PAL SIF (352x288/25fps), audio[0]: l2/44.1kHz/224kbps/stereo ...
finished ok, image created with 268324 sectors [59:37.49]
Cdrdao version 1.1.5
0,0,0: MITSUMI CR-4802TE Rev: 2.1D
Using driver: Generic SCSI-3/MMC (raw writing) - Version 2.0 (options 0x0000)
Starting write at speed 2...
Using 16 byte P-Q sub-channel data mode.
Executing power calibration...
Power calibration successful.
Writing lead-in and gap...
Writing track 01 (mode MODE2_RAW/AUDIO)...
Writing track 02 (mode MODE2_RAW/AUDIO)...
Wrote 268324 blocks. Buffer fill min 96%/max 100%.
Writing lead-out...
Flushing cache...
Writing finished successfully.
Did I do something else wrong?
before you burnt did you analyze you .xml file? It's show entrie points in seconds ya know. Also have that analyze mpeg checked
It's creating entry points, not splitting your MPEG. VCDImager will still process the video as one file, but the next/prev chapter functions will work correctly.
Here's the XML file
<?xml version="1.0" ?>
<!DOCTYPE videocd (View Source for full doctype...)>
- <!-- Made with VCDImager Easy v1.0.1
- <videocd xmlns="http://www.gnu.org/software/vcdimager/1.0/" class="vcd" version="2.0">
<option name="relaxed aps" value="false" />
<option name="leadout pause" value="false" />
<option name="track pregap" value="150" />
<option name="track front margin" value="30" />
<option name="track rear margin" value="45" />
- <info>
<album-id>X_MEN</album-id>
<volume-count>1</volume-count>
<volume-number>1</volume-number>
<restriction>0</restriction>
</info>
- <pvd>
<volume-id>X_MEN_PART_1</volume-id>
<system-id>CD-RTOS CD-BRIDGE</system-id>
<application-id>CDI/CDI_VCD.APP;1</application-id>
<preparer-id />
<publisher-id>VCDIMAGER_EASY_V101</publisher-id>
</pvd>
- <filesystem>
- <folder>
<name>CDI</name>
- <file src="C:\WINDOWS\DESKTOP\DOWNLOADS\VCDIMAGER\Cdi\CD I_IMAG.RTF" format="mixed">
<name>CDI_IMAG.RTF</name>
</file>
- <file src="C:\WINDOWS\DESKTOP\DOWNLOADS\VCDIMAGER\Cdi\CD I_TEXT.FNT">
<name>CDI_TEXT.FNT</name>
</file>
- <file src="C:\WINDOWS\DESKTOP\DOWNLOADS\VCDIMAGER\Cdi\CD I_VCD.APP">
<name>CDI_VCD.APP</name>
</file>
- <file src="C:\WINDOWS\DESKTOP\DOWNLOADS\VCDIMAGER\Cdi\CD I_VCD.CFG">
<name>CDI_VCD.CFG</name>
</file>
</folder>
</filesystem>
- <sequence-items>
- <sequence-item src="C:\My Documents\Mi2\Mi2 Part 1.mpg" id="sequence-00">
<default-entry id="chapter00-00" />
<entry id="chapter00-01">300.000</entry>
<entry id="chapter00-02">600.000</entry>
<entry id="chapter00-03">900.000</entry>
<entry id="chapter00-04">1200.000</entry>
<entry id="chapter00-05">1500.000</entry>
<entry id="chapter00-06">1800.000</entry>
<entry id="chapter00-07">2100.000</entry>
<entry id="chapter00-08">2400.000</entry>
<entry id="chapter00-09">2700.000</entry>
<entry id="chapter00-10">3000.000</entry>
<entry id="chapter00-11">3300.000</entry>
</sequence-item>
</sequence-items>
</videocd>
I did analyze the Mpeg file before.
In the chapters settings I did have a list with a chapter every 5 mins which shows in the xml file but my DVD player does not see them? Also tried with Power DVD on computer with same results?
What's wrong?
<font size=-1>[ This Message was edited by: MicoMan on 2001-10-04 07:39:28 ]</font>
MultiAVCHD problems; chapter selection crashes program; changing title
By Yanta in forum Newbie / General discussionsReplies: 0Last Post: 14th Sep 2011, 16:48 -
MKV chapter file extraction problems
By ikarishinji41 in forum EditingReplies: 1Last Post: 22nd Mar 2010, 11:03 -
Is there any easy way
By kemcel in forum MediaReplies: 1Last Post: 17th Mar 2009, 08:07 -
DVDLab Pro output Chapter problems
By ArtOfLosingMFZB in forum Newbie / General discussionsReplies: 4Last Post: 9th Mar 2009, 20:38 -
GUI for dvdauthor - How to make chapter thumbnails run the chapter video
By deco81 in forum Authoring (DVD)Replies: 4Last Post: 15th Dec 2008, 11:51
