I want to make a DVD-R from clips extracted from several music DVDs. I don’t have a problem extracting and combining the different segments, but I don’t like the way they make the transition between clips. Is there a way to make the beginning of each segment fade-in and the end fade-out, without having to decompress everything to avi for edition?
You could do it in AVISynth
Ejoc's CVD Page:
DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
DVD:
DVDShrink -> RecordNow DX
Capture:
VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author
Help for adding Fade In/Out and Joining many clips together
By joberrick in forum EditingReplies: 1Last Post: 11th Jul 2011, 20:44 -
Can I do a simple fade in/out on clips pulled from BD without re-encoding?
By Dan Miller in forum EditingReplies: 4Last Post: 7th Jun 2010, 00:31 -
VirtualDub: Fade between clips effect
By David_UK in forum EditingReplies: 5Last Post: 14th Apr 2009, 14:25 -
Separating 2 Clips joint by fade in effect?
By InSaNiTy in forum EditingReplies: 0Last Post: 3rd Aug 2007, 14:19 -
how can I add "Fade in / Fade out" effect in my video clips
By mb508 in forum EditingReplies: 5Last Post: 9th Jul 2007, 16:02
