EVERY TIME I TRY TO BURN A BIN FILE IT WON'T PLAY ON MY APEX.I USED VCDIMAGEGUI TO TRY TO GET FF AND RR TO WORK ON SVCD.HAS ANYONE DONE THIS SUCESSFULLY.I AM USING NERO TO BURN.
btw, writting in CAPS isn't extremely polite...
please see
http://www.vcdhelp.com/phpBB/viewtopic.php?topic=49767&forum=1
and
http://www.vcdhelp.com/phpBB/viewtopic.php?topic=49024&forum=1
for some hints... -
I have had the same problem I burn a bin file discjuggler and it worked do not use CDRWIN even if you see a cue sheet. stick with Discjuggler. Also even after burning the bin file it did not work on a APEX 600a or a 660a it only worked in my pc and a PSX with a VCD card I only found one DVD player that would play this VCD the GPX DV2000 I found in this to be better then a APEX but APEX is a little better with CDR"S working the GPX plays CDR well to Imation PNY MEMerox but not Veberation. So it's a little nice to have both a GPX and A APEX
bin subtitles
By smittenjey in forum Authoring (VCD/SVCD)Replies: 4Last Post: 7th Jan 2011, 15:20 -
bin files
By fredreed in forum DVD & Blu-ray PlayersReplies: 2Last Post: 15th Nov 2009, 01:02 -
Recycle Trash bin
By bryankendall in forum Newbie / General discussionsReplies: 2Last Post: 26th Apr 2009, 13:11 -
Recycling Bin
By Nitro89 in forum ComputerReplies: 6Last Post: 20th Feb 2008, 08:02 -
Bin file
By anton225 in forum Video ConversionReplies: 3Last Post: 4th Jul 2007, 13:05
