Results 1 to 16 of 16
The disc is DVD9 but the total file size is less than 4.3GB. I would just back it up as if it was a DVD5 disc with DVD Decrypter:
1. Choose "Mode | Iso - read" and rip image file
2. Choose "Mode | Iso - write" and burn image file -
Thanks for the advice. Unfortunately dvd decrypter was tripped up by the disk as well. Any other thoughts?
I tried to back this up as well with only one success. If I use dvdxcopy express to just get the movie it would work fine. Otherwise it would not play back correctly. If someone does get a good working backup with everything in tact please let me know because I would love to know how it was done.
are u sure u are using dvd-decrypter in iso mode. I have successfully read and wrote an iso of Stich the movie to dvd-r
check out http://www.geocities.com/eatin_sammiches/sprucecreations.html to download additonal buttons and backgrounds for SPRUCE-UP menu creation -
I don't have this DVD but if it really is a dual layer disc with a total size of 4.3GB or less then this should work:
1.) RIP with DVD DECRYPTER using FILE MODE and select ALL files
2.) Use ImgTool (classic version) to create an ISO IMAGE file
3.) Burn the ISO IMAGE file with DVD DECRYPTER
Should work
Gmatov,
I'm on the current version (6.0.0.15), and it works just fine. I have never used Nero for anything other than data or image burning, and for those it works just fine. It also makes fine duplicates when AnyDVD is running in the background.
People who dislike it try to use it for other things.
- Gurm -
Did you use the Beta 5 version of DVD shrink?
I did a back up of Stitch the Movie using the Beta version without any problems.Just shut up and listen dumbass -
Just out of curiosity, but why on earth would you use DVD Shrink on a movie that's smaller than a DVD-R?
- Gurm -
For myself I generally do not use it on a DVD5 but the original post said he had tried DVD shrink, with others, and had no success, since I had bought the movie for my son I thought I would try backing it up using DVD shrink, and possibly duplicate the problem.Just out of curiosity, but why on earth would you use DVD Shrink on a movie that's smaller than a DVD-R?
- GurmJust shut up and listen dumbass -
Here's the summary verison Grum. The it's a DVD9 disc, but only 4.1GB total file size. So you can fit everything on a single DVDR. Myself and others have just ripped an iso file w/ DVD Decrypter then burned the image. But that's not working for the original poster. It was suggest that maybe this is because of the layer break commands in the IFO. So why not rip in file mode, run it through DVD Shrink (no compression) to remove them (or use IFOEdit).
But given that myself and several others have had no problem backing up this movie I suspect that there might be something wrong with either his setup or his DVD source.
Stitch multiple videos into one frame
By mikeusru in forum Newbie / General discussionsReplies: 5Last Post: 19th Aug 2013, 03:45 -
Avidemux - won't stitch Flip Mino HD files properly ?
By andy15star in forum EditingReplies: 4Last Post: 28th Aug 2011, 04:37 -
I'm having probs with MPC-HC
By HartsVideo in forum Software PlayingReplies: 8Last Post: 10th Feb 2011, 21:47 -
Glue/Stitch a series of .avi files...
By midiw in forum ffmpegX general discussionReplies: 2Last Post: 23rd Jan 2011, 14:03 -
Editing a movie for Youtube. Probs with avi
By jwalter007 in forum Newbie / General discussionsReplies: 2Last Post: 30th Jan 2010, 07:32
