Ok im trying to burn a vcd using Ezcd ( i know its crappy to use) ok it said the bitrate was to high at 2000 so i lowered it to 1150, thats fine, now it says "SYSTEM CLOCK REFERENCE - 1085" aparently thats too high someone let me know what this should be set at and how to do so.
I am also having the same problem. How do you change the system clock reference and what should it be set at. I am using nero to try and burn a SVCD. I used TempGEnc to encode to Mpeg but when i go to burn with nero it says file format invalid and EZ CD creator 5 says clock reference is wrong. Any help would be appreciated. I am fairly new at this
Thanks -
The "system clock reference" error from Easy CD Creator refers to the fact that the pack size of the MPEG isn't correct for VCDs.
Assuming all other specs are correct, you can easily fix this by demultiplexing and remultiplexing the mpeg. You an do this with bbMPEG or TMPGEnc. With TMPGEnc, be sure to select "MPEG-1 Video-CD" rather than "MPEG-1 Auto".
Regards.
_________________
Michael Tam
<font size=-1>[ This Message was edited by: vitualis on 2001-10-03 16:22:27 ]</font>
Unusual behavior of PC clock
By Seeker47 in forum ComputerReplies: 7Last Post: 22nd Aug 2009, 12:34 -
Atomic clock sync not working
By bevills1 in forum ComputerReplies: 30Last Post: 9th Mar 2009, 12:19 -
phillips 3575h clock problem
By resohed in forum DVD & Blu-ray RecordersReplies: 2Last Post: 29th Oct 2008, 17:44 -
Fall for Recorder Clock
By UnknownVT in forum DVD & Blu-ray RecordersReplies: 8Last Post: 12th Nov 2007, 09:06 -
Trutech 1620 clock
By jaybird206 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 18th Jun 2007, 14:20
