What is the best solution to mix VCDs and SVCDs to one CD-R?
I mean I would like to make a music video collection to one
cd with menus. I use TMPGEnc DVD Author to make menus,
but I can't import VCDs and SVCDs together to one project.
What can I do to solve this problem?
I know that I could encode all files to SVCD or VCD format but
then I would get quality loss. Is there any way to burn to burn
them without having this problem?
And I also noticed that TMPGEnc DVD Author doesn't allow 23.976 FPS (NTSC Film)
format only 29.97 FPS (NTSC) and 25 FPS (PAL)
So I need also help to convert NTSC Film to PAL or NTSC. Can I do that without
re-encoding? And without qaulity loss?
Can't be done. VCD and SVCD use different file formats (see what is sections to left). You can mix VCDs and xVCDs, or SVCD and xSVCD on the same CDR thou.
A miniDVD would work, but then you have little player compatibility (except for great catches like my Norcent 300 8) ). Only thing needing to be changed would be the SVCD patching for DVD compliance.
>>>>edit
Make sure you put the different varieties each on a separate VTS, cuz otherwise it absolutely won't work.
Mixing Frames.
By Xypher in forum Newbie / General discussionsReplies: 12Last Post: 22nd Sep 2011, 03:42 -
Mixing D1 and HDV
By bdr13278 in forum EditingReplies: 4Last Post: 12th Sep 2009, 13:26 -
mixing 2 mp3s together
By motleycool in forum Newbie / General discussionsReplies: 2Last Post: 26th Jan 2009, 09:04 -
5.1 surround mixing
By namesake in forum Newbie / General discussionsReplies: 11Last Post: 10th May 2008, 22:22 -
Mixing 5.1 - What Software Should I use?
By scottrwn98 in forum AudioReplies: 0Last Post: 11th Sep 2007, 15:11
