Everytime i use the copy to copy a dvd from the dvd drive and write after a few minutes are quite along way through doing a movie, i can these error
Data Job Terminated with errors
error 10 at sector 15066
disc writeerror command 2a Sense :03 ASC:0c ASCQ:00
Whats this all about? its making me lots of coasters,
Ive swapped from nero 6 as that made dvd problems and many ppl have said it has bugs making dvds and recommended this new program, but ive still had more problems than successful burns.
Can anyone help? had this problem and solved it?
Is it a reading error from my source disk?
could be errors on the source disk or bad write media or it could be a buffer underrun (most likely) try ripping the source to the hdd first (use dvd decrypter or smart ripper both are free programs) the burn with record now max. Also make sure dma mode is enabled, if you still get errors then its most likely the write media wot media are you using and what dvd-rw drive are you using ?
it could be a few things:
1. your computer is not fast enough to do a full dvd-dvd copy.
2. the material you are trying to copy might be copy protected.
3. it could be the media you are using to burn
usually when record now gives an error like that it sees something wrong with the disc (this kind fo error also appears when a dvd is authored wrong or a ripped disc is missing files) -
or a bad burner
Try to switch to different DVD media.
I got a lot of coasters when I used Longten 4X DVD-R and a bad batch of Princo 1x DVD-R.
And since I switch to B's Recorder Gold 5, I'm be able to burn 100% successful rate with both Longten and Princo's.
Dual DVD recorder that will record 2 DVDs with the push of one button?
By KevinBon in forum Newbie / General discussionsReplies: 11Last Post: 14th Mar 2011, 17:25 -
What is max bitrate and max channels supported by PCM audio format?
By Bonie81 in forum Newbie / General discussionsReplies: 10Last Post: 19th May 2010, 00:35 -
HDD/DVD recoder doesn't record or play dvds
By maybell in forum DVD & Blu-ray RecordersReplies: 5Last Post: 1st Mar 2010, 14:09 -
My Pioneer DVR-533H-S won't record DVDs or finalize them!
By superman123x in forum DVD & Blu-ray RecordersReplies: 4Last Post: 31st Jul 2008, 18:22 -
Max I Frames on DVDs
By SCDVD in forum Newbie / General discussionsReplies: 2Last Post: 4th Jun 2008, 19:19
