Hi. I would like to know how to get the best quality encoding in mpg1 direct from DV files. I have tried some settings, but the quality wasn't acceptable. I would like a near DV quality, but with a smaller size. Any hints?
thanks in advance
Mario
mariocardosoGuest
Maybe CVD is my answer? I too I'm not having great results of coverting DV into MPEG1 or MPEG2. The results still look quite pixelated. I am often downloading music videos from alt.binaries.mpeg.video which are about 4 minutes in length and are about 50-60 megs in size. The quality is really really good-almost zero pixelation and close to VHS quality. When I go to find out what type of files it is with ffmegX or MPEG Info, I don't receive any info. I'd really like to duplicate those formats. I hope CVD is it?
Okay, thanks. So then why would the VCD files that I create (converting a DV file that I imported from my video camera into a VCD file using ffmegX) look so crappy compared to the ones I download? Is there a setting in the VCD preset that I can change to improve the quality? I tried increasing the Bitrate, but that seems to have no effect.
By the way, I hope I wasn't too negative with the "crappy" description. I am not saying the ffmpegx is to blame here or is below standard. I am simply struggling with why my VCD (mpeg-1) videos are not coming out a clear as most of the ones I'm getting from alt.binaries. I didn't know if there was some standard setting I'm missing.
I could ask the people in the newsgroups, but I think all of them are on Windows and I am unsure of the right questions to ask.
Difference/Relationship among encoding, re-encoding & decoding?
By iqbal88 in forum DVD RippingReplies: 12Last Post: 19th Aug 2011, 14:46 -
Encoding MKV to MP4 with .ass subtitles without re-encoding.
By smilegreen in forum Video ConversionReplies: 7Last Post: 26th Apr 2009, 14:11 -
VCD MPG1 file to CD Question
By Excelsior123 in forum Authoring (VCD/SVCD)Replies: 21Last Post: 22nd May 2008, 19:14 -
avi to mpg1
By zoranb in forum MacReplies: 3Last Post: 12th Sep 2007, 14:46 -
Minimum MPG1 file size?
By Choppa in forum Authoring (VCD/SVCD)Replies: 17Last Post: 17th Jun 2007, 23:04
