A friend sent me a VCD which I can't seem to make a copy. It does seems to have problem playing on one of my DVD players. So I'm trying to fix it using TMPGEnc's De-Multiplex. However, after I loaded the video and audio files and hit Run - TMPGenc gave me an error saying illegal video stream. What does this mean?
Is there any other way to fix a VCD and burn it onto a new CD? By the way I was following this fix guide https://www.videohelp.com/forum/userguides/126673.php
when you do this in TMPGENC, is the tab at the top say Video-CD or does it have another option? It should say video-CD.
What "problem" does the VCD have when you play it on your dvd player that you have confirmed plays VCD (not just CD-R). Do other VCd's play OK. Is the VCD a true spec'd VCD (1150bitrate, 44.1mhz audio, 23.976 or 29.976 fps *NTSC)
Does it play fine in your friends dvd player? It sounds like from what you wrote, the VCD is NOT a true VCD. Post the specs of the file.
What is this called and how do I fix it?
By jarlaxle in forum Newbie / General discussionsReplies: 5Last Post: 28th Feb 2012, 03:08 -
Is it possible to fix that ???
By cd090580 in forum Newbie / General discussionsReplies: 8Last Post: 8th Sep 2009, 15:46 -
fix vob
By forare in forum Newbie / General discussionsReplies: 1Last Post: 5th Mar 2008, 04:33 -
Can I fix a VCD?
By Haopengyou in forum Authoring (VCD/SVCD)Replies: 6Last Post: 1st Feb 2008, 00:26 -
How to fix Audio problem with vcd authoring
By thelotusman in forum Authoring (VCD/SVCD)Replies: 6Last Post: 16th May 2007, 11:20
