I have a problem with DVD Maestro. I have used it successfully for 2 years now, but ]following a PC crash I re-installed everything from scratch including DVD Maestro. Now I can't get it to work at all, it just hangs on the splash screen.
I tried re-installing again with the same results, and even removed some other software but each time I get the same problem.
The only changes I have made to my system is to add bluetooth software for a USB Bluetoothadapter and a Bluetooth printer module but I cannot see this being the problem.
Has anyone had any similar problems, or can anyone offer any help/suggestions?
although it's no longer sold, I am pretty sure that Spruce is still supporting Maestro - if you go to the Spruce website, I think it has contact information for tech support.
- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
you know... that piece of hardware that came in the box with your software and your manual... the one that plugs into the back of your computer and acts as a hardware key for it.Originally Posted by wy685mm
what's that I smell? fish?- housepig
Housepig Records
out now:
wy685mm, where did you get your copy of Maestro. The dongle should have come with it.
spruce (owned by appple) support has totally run out now ... apple doesnt support thier big corp customeers on this anymore - but wants us to buy dvd pro 2 (which is good product) ... offfcially , the story is that maestro has support for ONLY nt4 and nothing else .. (apple stopped making updates also for shake for windows - which is pissing off MANY people let me tell you - so much i know of one company that just dumped mac from their company totally because of it) .. if you buy a company - dont kill it as you have done with RAYZ, Chalice, Spruce , Shake and a few others ..
yea , you have to install the dongle and dongle drivers for it to work .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Different installation problem
By dmf in forum ffmpegX general discussionReplies: 9Last Post: 11th Jan 2012, 16:02 -
I have some problem with wvc1dmo installation.
By Dboyz in forum Newbie / General discussionsReplies: 0Last Post: 10th Sep 2009, 04:23 -
FLVtool2 installation problem
By linea in forum ffmpegX general discussionReplies: 34Last Post: 15th Dec 2008, 13:09 -
Problem with the installation!
By defacta in forum ffmpegX general discussionReplies: 3Last Post: 20th Jul 2007, 00:37 -
By gokes in forum ffmpegX general discussionReplies: 1Last Post: 10th Jun 2007, 04:55
