  1. HI:
    Does anyone now where can i find a CHANGECD PIC to add to my, (s)vcd??
    IM using tmpgenc to enconde and DVD moviefactory 2 to create the chapters,and introduction etc etc, i just need to find a changecd pic, to add to the end of the first cd.!
    thanks a lot!
    I WAS YOUNG ONLY ONCE, BUT I CAN BE IMATURE FOREVER!
  2. Those are still mpg's, right? I've read a million tutorials/guides and i think i learned something about this. You make a still MPEG, and add it to your SVCD, so it would be like Movie1.mpg and Changecd.mpg. Then you change the Changecd.mpg to infinite, like the menu, that way it stays until you change the cd.
  3. Banned
    Nov 2002
    Pgh Area
    I may be wrong....
    I use DVD2SVCD, and it make a file for change CD, but think it is added when I tell Nero to make menu. Can't really remember if I ever didn't check that box.
    I AM pretty sure it takes the change mpg from the folder DVD2SVCD converted to.
    If you are looking for something more fancy than a white on black gloved hand holding a CD, then ignore this response.
  4. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Nope, they are mpg movies. I tend to loop them for ever at the end of CD1. Pretty cool, actually.I particularly like the "Disc 1 to 2" sequence. I've reencoded them as SVCD too, for my SVCD projects.
    /Mats
