When capturing old VHS tapes to convert to DVD, will the output from a SVHS jack give a better picture than using the composite outputs on a vcr?
I have vidoes on tape since 1984. Someone told me I would get a better capture if I used a SVHS VCR. I cannot understand how this coulf be. The video tape was recorded in 1984 on a mono vcr in EP mode. Will it or will it not matter if I use the SVHS output compared to the composite output?
Except that the sVHS player might be a better quality player you are right in assuming that the quality of the tape is the same. The main difference is that sVHS players usually come with S-video out which would mean less signal loss through the cable, which in turn reults in a better picture.
Nothing that is going to make an old bad noisey tape good mind you, just a little less bad. -
The main difference between vhs and svhs is that the svhs video output is seperated into two channels, chroma and luma. These are basically color and brightness. It also has a higher bandwidth than vhs. But unless you are playing a svhs tape, you are unlikely to see any improvement over vhs. Svhs recorders are more expensive and break down just as much as a high quality vhs machine. Cheaper to buy a medium quality vhs machine and replace it once a year as I have been doing. Old vhs tapes are hard to get a good quality encode from. Good luck.
Having transferred 200+ VHS tapes that are approaching 23 years of age, I would say the improvement is minimal but can be noticed in certain situations, particularly screens with an abundance of reddish colors.Originally Posted by CT2
This opinion has been formulated after using a Sony SLV-R5U with a "Demo" Monster Cable THX-1000 S-Video cable. Is the perceived improvement in picture worth the $1100 for this combination?
Hardly. Go for a VCR with TBC. You will be pleasantly surprised. -
I believe, technically, you do get a better picture using S-Video output. I also believe that I could show you the finished product using both methods and you couldn't see the difference. It's something that can, for the most part, only be 'seen' electronically. If you were a professional technician, then maybe you might be able to actually see the difference. Very marginal.
talking about plain vhs tapes your benefit of using the Svideo connection is zero.
absolutely waste of time and....wires..
if you want to try something effective you should try a video baseband
corrector amplifier.
With this you can control things like colour correction,britness,contrast,increase the high frequencies of video bandwith for better resolution,etc.
i use something like this but dont ask me where to buy it,i maked it my self.
Help settle a bet...
By SquirrelDip in forum Off topicReplies: 14Last Post: 4th Jun 2007, 02:52
