Have used this tool and it just simply works - it's the puppy's privates.
BUT If I use TMPGEnc to burn the created output the discs WON’T play on my “arianet dvd-2277” but WILL play on my mustek player?!?
If I burn the same output with Nero 6 (DVD-video option) disc works on both?
Anyone got any ideas ideas?
Media TDKG02
Burner - Optorite
O/S - W2k sp4
Yep, thats what I am doing, just wonder'd if anyone else had had a problemBurn it with Nero
Had a look at discs with DvdInfo and results are below
This disc plays in Mustek, Pacific & Arianet (Nero DVD-Video)
This disc only plays in Mustek (TMPGEnc DVD Author)
Only diff I can see is Implementation id & Volume name
As one can see both use UDF 1.02 (as I thought 1 app might not be - from reading other posts on nero)
Oh well ! any input welcome... -
Update
I'm still getting the same problems with Identical media/files (dvd-r)
however tried same files with a dvd-rw and TMPGEnc DVD Author and that worked.
yeah, he said he burned one with nero & the other with TMPGEnc DVD Author , it says prassi when checked after burning with TMPGEnc DVD Author , but i have not had this problem yet ? i actually had dvd+r's work in machines that are listed on this site as not working with dvdr's, burned with both programs, in both "+" & "-"Originally Posted by FOO
Haven't used it with a DVD+R yet (TMPGEnc DVD Author) they cost me too much and I don't need any more coasters.
Still think it's strange why DVD-RW work
Why haven't pegasys-inc got a 'report bug' page on their site? (or do they use this site for bug reports
You can only get support if you purchased the product.
I like this proggie but would not pay for it unless the burning issue got cleared up (or am I the only 1 with this problem)
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 12:10 -
Strange region problem with DVD Shrink re-author
By Jetter68 in forum DVD RippingReplies: 7Last Post: 30th Aug 2008, 15:14 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07 -
Strange error message when re-authoring with TMPEGEnc DVD Author 1.6...
By justin81 in forum Authoring (DVD)Replies: 3Last Post: 24th Sep 2007, 02:23
