hi i have an svcd but unfortunately it is not in an iso or bin/cue format it is instead just the files pulled off a cd. so i basically have the 4 folders: ext, mpeg2, segment, svcd. now i could just create an svcd with nero and put in the mpeg however i want to use the chapter information etc, so what im asking if thers anyway of putting all these folders back into an iso
I believe you can just create an iso disk and drag/drop the folders you have to create the SVCD.
Follow this guide:
https://www.videohelp.com/forum/userguides/141726.php#svcd
After you have gotten the mpg back then burn with nero in the svcd mode as you normaly would.
Frustrated trying to burn SVCD
By InfoSeek in forum Newbie / General discussionsReplies: 15Last Post: 8th Mar 2010, 20:34 -
Can I burn VCD or SVCD on DVD±R/W?
By Baldrick in forum Authoring (DVD)Replies: 111Last Post: 30th Aug 2008, 16:38 -
How to burn a SVCD onto a DVD?
By php111 in forum Authoring (VCD/SVCD)Replies: 9Last Post: 16th Oct 2007, 02:32 -
Freeware app to burn SVCD's?
By louv68 in forum Authoring (VCD/SVCD)Replies: 4Last Post: 18th Jul 2007, 14:28 -
Xvid to svcd + burn...
By Crapozo in forum Newbie / General discussionsReplies: 7Last Post: 25th May 2007, 05:07
