I used Divo to capture DV through a firewire to my system.
Video looked good, but no sound??? First I captured from the camcorder with just the firewire attached, no sound.
There IS sound on the tapes! Played back to TV is fine, though I would like to encrease the volume some.
So then I connected the audio cables to the ATI card which is conneted internally to the onboard sound. Still no sound. I thought it might act as a pass through.
I thought since it was DV, (data?) that it would all be in one file from the firewire. What happend?
I was a dummy on this too. I captured 2 hours of tape over the firewire the first time, then the 3 files were about a total of 20gigs AVI. So I ran that through Tmpgenc to convert to Mpeg2. It showed the audio settings, stereo ect.. as if it were there. Then after 4 hours of encoding there was no sound! That's when I checked the AVI files, and they had no sound when played either.
SO totaly new to DV, How do I get my DV camcorder tapes onto my PC using firewire and have sound too?? No info with the camcorder! Just syas connect cable and see software/pc manual (which doesn't exist of course)
Also, as a DV AVI, is this gonna take 4 hours to encode to mpeg2 everytime I do one? Did I do something wrong there too? Is there a faster way to just convert when not doing anything else to it?
Alot of stuff I will just want camcorder to mpeg2 for authoring and not be doing much else.
Though I plan to work on this project ALOT for learning. I need to reduce the red, compensate for washout from bright lights, and also increase volume level since the people were a bit distant. Sound is good, but to low.
I did the first DVD as a composite capture yesterday since I could not get the DV with sound, I'm not happy with it! I'll need 9 of these DVDs and several VHS tapes soon.
Yes, you are right, DV should be one file containing both video and audio and the Firewire connection should give you both. The fact that TMPGenc shows the audio settings means that there is an audio component there, it just doesn't have any noise on it!Originally Posted by overloaded_ide
I'm not familiar with Divo but maybe there is a setting somewhere that means you have told it not to capture audio. This might then explain why you aren't getting audio when you connect the analogue too.
Good luck -
DIVO is extremly simple.
Click file, tiny box opens, browse to location to save capture and type in filename, click capture, turn on device.
No settings or anything! Only used it this once, so far.
It looked great though, only captures while it gets a signal. So click capture and it does nothing till you play the camcorder then it starts capturing. Stop the camcorder Divo stops capturing, start camcorder capture starts.
I love that part of it, no blank screens before or after when your turning stuff on and off, just captures when the signal is present.
I don't know why I have no sound then if I was correct and it should be in the firewire capture! -
I am getting sound durring an analogue capture, like playback from the camcorder though the ATI AIW card and capturing drect to mpeg2, but not with DV capture.This might then explain why you aren't getting audio when you connect the analogue too.
Hi, If you start DVIO first, then you may get no sound. Try starting the camera first and see what happens. I had that problem and this fixed it.
"Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey
does capture of firewire use the sound card?
By Cazz in forum Capturing and VCRReplies: 4Last Post: 24th Jan 2010, 16:45 -
Capture stereo sound and quality video from analog camcorder to dvd
By gxwarr in forum Video ConversionReplies: 1Last Post: 6th May 2009, 16:39 -
Capture from Sony Camcorder/Firewire connection stopping in 4-12 seconds
By tepeco in forum Capturing and VCRReplies: 4Last Post: 16th Apr 2009, 11:24 -
Divo Codec
By spysr in forum Video ConversionReplies: 6Last Post: 5th Oct 2007, 15:18 -
What Firewire Card for a Camcorder?
By rakun in forum ComputerReplies: 5Last Post: 12th May 2007, 09:20
