i have a divx file thats only 20 minutes so i wanted to convert it to mpeg but the problem is when i did that the file was over 800 megs this kinda puzzled me , so i figured since the audio that was making it soooo large , so i wanted to know what programs could i use to downsample the audio or does ne one have ne other solutions
Did you use tmpgenc to convert it? if so did you use any template such as vcd,svcd or dvd?
On 2001-10-03 20:36:07, too2buff wrote:
yes i use tmpenc and i used the vcd template
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Then you will end with a 200MB mpeg, definitely.
Load the video source first and after that the template.
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2018, 19:16 -
Problem burning .avi file to dvd.. Burner tells me file is too big when not
By accesskb in forum Newbie / General discussionsReplies: 17Last Post: 6th Mar 2012, 18:28 -
creating many small clips w/ mpeg ts file
By Funkymoses in forum Newbie / General discussionsReplies: 1Last Post: 6th Sep 2010, 11:53 -
cut one MPEG file to many small mpeg file automatic
By Cazz in forum EditingReplies: 2Last Post: 8th Aug 2010, 11:11 -
How to go from DVD to small MPEG file
By jester805 in forum Newbie / General discussionsReplies: 10Last Post: 17th Oct 2008, 19:15
