I have bought a new LG 4040b triple format burner but one of the RW discs i have was used with HP's DLA burning program... i dont have it anymore and nero will not format the RW, it says 'illegal disc'
Are their any other programs that can completely erase my RW so i can use it normally again? thankyou
thanks, but when i open it, i see a little icon on the systray, but when i move my mouse over it it dissapears, program quits as soon as i try to open it, any help?
I have proven a few times that DLA screws with RW especially +RW. Uninstall DLA, and any problems you are having with RW should disappear.Originally Posted by kraad
Now are you saying my program disappears as soon as you run it?? Have you downloaded the latest from my web site?
www.dvdinfopro.com
cheers
nicw
author dvdinfopronicw -
ya ive seen it run on my friends puter works & looks awsome, when i open it now its just freezing, i see a blank window come up and its stuck there
Save heaps of forum posts. Email me direct on this and I cannot assist you to find the problem.Originally Posted by kraad
nicw@bigpond.net.au
cheers
nicw
authornicw
What is this called and how do I fix it?
By jarlaxle in forum Newbie / General discussionsReplies: 5Last Post: 28th Feb 2012, 04:08 -
Fix my Speakers
By carreaza in forum AudioReplies: 4Last Post: 14th Oct 2011, 21:57 -
Is it possible to fix that ???
By cd090580 in forum Newbie / General discussionsReplies: 8Last Post: 8th Sep 2009, 16:46 -
how to fix h264?
By hanugro in forum Newbie / General discussionsReplies: 9Last Post: 13th Mar 2009, 23:02 -
AVI, Nothing will fix it! I have done all I know!
By bl00dy fl00r in forum Newbie / General discussionsReplies: 5Last Post: 3rd Jun 2007, 19:02
