i just got through encoding "clerks" to divx with vidomi.
it made 2 files
clerks.avi 736,282,624 bytes [702mb]
clerks1.avi 806,912 bytes [788k]
i then decided i didnt want 2 seperate files, so i decided to merge them through virtual dub.
i opened "clerks.avi", set "video" to "direct stream copy" the same for audio. i then "append avi segment" and added clerks1.avi. it merged them together, and the file plays just fine and dandy. the only thing is the merged file is;
734,732,288 bytes [700mb]
why is it when i merge the 2 files together, the end result file is smaller?
is it lowering the quality of the video or something?
thanks for any help
How is a Smaller File a Better One?
By happydog500 in forum Capturing and VCRReplies: 4Last Post: 23rd May 2011, 20:50 -
Best way to convert DV file to something that have smaller file size
By Cazz in forum Video ConversionReplies: 27Last Post: 8th May 2010, 06:14 -
.TS to a SMALLER file with nearly SAME QUALITY
By Benygh in forum Video ConversionReplies: 2Last Post: 12th Dec 2009, 10:23 -
Transcodeing HD or BD to smaller file
By wulf109 in forum Blu-ray RippingReplies: 4Last Post: 28th Dec 2008, 10:20 -
how do i make a file smaller?
By Sanosen in forum Newbie / General discussionsReplies: 5Last Post: 28th Sep 2007, 22:57
