I just purchased this capture card from newegg. I'm curious if it'll be capturing using a software based method or if it's going to use a hardware method like the Canopus ADVC-100 Analog to DV Video Converter.
I only have the one main system and I do some VERY heavy multi-tasking on it.
Canopus ADVC1394 Advanced Digital Video Converter & OHCI PCI interface
In one easy to install PCI card the ADVC-1394 features:
> Analog video to DV conversion and capture through OHCI in realtime.
> VideoCD, Super Video CD and DVD authoring.*
> Capture to MPEG-1*, MPEG-2*, and DV.
> Powerful editing and content creation applications:
Vegas Video LE 3.0* and WinProducer 3 DVD*.
> Adjustable brightness, contrast, saturation, hue and sharpness controls for analog input.*
> Easy connectivity of high-speed storage devices, scanners, CD-RW drives and more.
> Locked audio support.
> NTSC and PAL video compatible.
> Simple Plug and Play installation with native OS driver support.
> Windows and Mac compatible.
Proven DV CODEC Technology
Canopus's proprietary DV codec technologies provide ADVC-1394 with the best picture quality preservation during analog to DV conversion.
Locked Audio Support
Other converters can lose audio/video sync when capturing longer clips of analog video. ADVC-1394 is the first inexpensive OHCI card that supports locked audio when capturing from analog to DV, ensuring perfect audio and video synchronization
Digital Video in/out
> 4-pin IEEE 1394 connector
IEEE 1394 Input/Output
> 6-pin IEEE 1394 connector
Analog Video Input
> S-Video and Composite combined(mini DIN 7-pin)
Analog Audio Input
> 1 x Stereo in (RCA)
OHCI specification
> Link layer complies with 1394 Open Host Controller Interface Specification release 1.1
> Physical layer complies with IEEE1394a-2000 (Data rate : 100/200/400 Mbps)
> Modular 32-bit host interface complies with PCI Specification release 2.2
ADVC-1394 Front Bay (optional)
> S-Video (mini DIN 4-pin)**
> Composite (RCA)**
> Stereo Audio (RCA)**
Canopus ADVC-100
Results 1 to 1 of 1
Capture some TV programmes via some sort of PCI card?
By The FNG in forum DVB / IPTVReplies: 4Last Post: 26th Jun 2010, 12:19 -
fpga based video capture card?
By mubi in forum Video Streaming DownloadingReplies: 0Last Post: 8th Jun 2010, 02:04 -
What Capture software can I use with the NVIDIA NVTV PCI TV Turner card
By JAYEDIN in forum Capturing and VCRReplies: 3Last Post: 19th May 2009, 01:55 -
Can anyone recommend a NTSC capture + video card based on this criteria?
By Rein Engel in forum Capturing and VCRReplies: 7Last Post: 5th Feb 2008, 08:25 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 18:15
