Hi, was trying to backup one of my dvd's using a multiple of programs, smartripper, DVDShrink, DVDDecrypter. However, the ripping process halts on the 4th VOB. The disk has scratches on it.
Has anyone got a solution for ripping dvd's with scratches???
Any help is much appreciated..![]()
Keep it Real !!
ok thanks for the quick response. I'll give that a go and let you know how I got on.
Cheers..
Keep it Real !! -
Still having problems with this disc. I enabled the "Ignore Read Errors" and it just keeps retrying and the number of read errors just increases. It ended up at 220 retries and 9 read errors before I killed it. It seems to crap out at 82%.
Ahhhhhhhhhhhhh.........
Anyone else got some suggestions ??????????...Keep it Real !! -
Try not ripping the bad VOB and just use windows explorer to copy the file to your hard drive. Now rip all the other files except the bad file then put the bad file into the ripped files folder. I have done that a few times with a 50/50 success rate.
Yeah, I'll give that a go. I didn't think you copy dvd files from explorer to to your hard disk but I'll try.
Thanks for your help....
Keep it Real !!
Rip DVD with scratch on it with DVD-Decrypter
By aslan in forum Newbie / General discussionsReplies: 17Last Post: 24th Mar 2013, 18:34 -
How to make a Karaoke DVD from scratch?
By MadeInBrazil in forum Authoring (DVD)Replies: 3Last Post: 15th Dec 2010, 12:06 -
Movie DVD with bad scratch
By johnsees in forum Newbie / General discussionsReplies: 11Last Post: 26th Jul 2010, 13:25 -
Is there any way to force rip a scratch dvd?
By tendra in forum Authoring (DVD)Replies: 13Last Post: 26th Jul 2009, 19:46 -
Better Scratch Resistance ...
By quantass in forum MediaReplies: 1Last Post: 20th May 2007, 12:59
