In one of the guides using Pinnacle InstantCopy, an instruction says you'll also need the update. Big bold letters with 3! (count em) 3! exclamation points say "Be sure to update if you haven't !!! " (see, 3)
But I went to the Pinnacle website for the update, and since their links didn't work either, I poked around in their forums and saw a LOT of complaints when people added the update. Crashes, errors, etc.
So what is so important about the 3! update that it might be worth the risk? In short, what does it do anyway?
PS is all the errors possibly why the link doesn't work anymore? they took it offline?
Burned DVD will work i9n more dvd players with the update by adding the audio_TS folder
if you want to know all go here
to the amn that knows all...
http://www.mrbass.org/instantcopy/ -
that's it?? an audio folder?
the info on the mrbass link looks the same as on pinnacle but most people said the speed and quality improvements were nil.
unless all the problems were an improvement by providing some computer debugging fun
but i guess my real question was why they made it seem so critical?
slight improved compatability doesn't seem enough
anyone using 7.1.1 (the update) help out with this?
How to disable Microsoft Update, not Windows Update?
By ukb007 in forum ComputerReplies: 17Last Post: 8th May 2011, 15:52 -
How to Update Your Duplicator's BIOS. you need to update
By krrish in forum DVD & Blu-ray RecordersReplies: 1Last Post: 29th Apr 2011, 12:02 -
Please update me on sw :-)
By boeniz in forum DVD RippingReplies: 7Last Post: 13th Apr 2011, 08:15 -
Ipod update..
By SE14man in forum Newbie / General discussionsReplies: 24Last Post: 3rd Oct 2007, 16:52 -
Windows Update?
By videobread in forum ComputerReplies: 1Last Post: 12th Jul 2007, 12:27
