I was hoping some of you experienced people could help me out with doing Divx 2 Pass Encoding with Premiere.
I have been doing it the way I've outlined below for over 6 months and its just too tedious. I usually capture about 7 TV shows that I want to encode and it takes a long time b/c I've got to setup each pass for each video.
The way that I'm currently doing it is:
1. Capture the video in Premiere
2. Edit the video in Premiere
3. File->Export Movie. (I export the video and audio seperately)
- At this stage I select the DivX 2 pass encoding
- This is where I need help b/c I have to select the first pass then let that run for a while (On a different computer). Then I have to select the 2nd pass then that that run for a while(On a different computer). And repeat this for each video.
4. File->Export Audio
5. Combine Video and Audio in VirtualDub
6. Finished DivX video
I would like to be able to queue up the first and second pass for each video and also queue up each video in sucession. This way I would spend maybe 30-45 minutes setting up the videos and then I could just leave it for 15 hours (or however long it takes).
Also, I know a few people will recommend that I just use VirtualDub for the whole process. The reason why I don't use VirtualDub for the beginning is b/c of its poor video editing capibilities. If someone knows a good way to make EXACT (down to a single frame) cuts (to cut out commericals) and then join together the video with VirtualDub or through another method/program then I would love to hear about it.
Thanks in Advance for the Advice.
Results 1 to 1 of 1
Difference Between 1 pass & 2 pass encoding
By iqbal88 in forum Video ConversionReplies: 28Last Post: 29th Oct 2021, 06:19 -
advantages of encoding vob/mpeg2 to h.264 using 3-pass instead of 2-pass
By codemaster in forum DVD RippingReplies: 8Last Post: 21st Sep 2011, 22:11 -
Retrospectively check if One Pass or Two Pass Encoding was used?
By BenjaminBS in forum Video ConversionReplies: 4Last Post: 26th Nov 2009, 06:46 -
Solved- How to do 2 -pass avi encoding with VirtualDub Mod
By jimdagys in forum Video ConversionReplies: 0Last Post: 23rd Nov 2009, 00:07 -
SVCD2DVD 2.5 One Pass vs. Two Pass encoding?
By mwkurt in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 19th Jun 2007, 15:55
