I have been having a problem with the new beta. I cant seem to use the reauthor feature consistently. More often than not, when you click 'reauthor' none of the files show up for drag/drop. Any ideas what might be the problem and a possible remedy?
huh/hmm?? Just to double check, you are aware that for DVD Shrink 3 (all betas) the re-author function has been modifed. When you click re-author it opens a new (2nd) windows. You can then drag/drop files from the 1st window, to the 2nd/new one. Then you hit back-up when you're ready.
Boy I hope this changes with the final release. 2.x was a lot easier and intuitive in the re-author mode. I love this program soooo much, but will probably stick with 2.x if the forced drag-n-drop thing stays.Originally Posted by Vejita-sama
I think the drag n' drop is much easier. I just put 2 DVDs together on one disk with it and it works perfectly. thats actually my first time using the Re-author function, and knowing me I try it with a more advanced project (combining DVDs) but it was easy as cake. ........ How easy is cake anyway?
I too think the drag and drop in DVD Shrink 3 is easier.
I rip both movies
Open DVD Shrink
Open first movie
Press Re-author (Window 2 opens)
Drag out first movie to window 2
Open Second Movie on window 1
Drag second movie to window 2
Close window 1
Do my biz on window 2
Backup
For those of you who don't already know, this is what the GUI for v3.0 Final (V3.1?) might look like:
http://forum.digital-digest.com/attachment.php?s=&postid=99761
Audacity Mac 1.3 Beta - solved my problem but how?
By Rhymester in forum AudioReplies: 5Last Post: 27th Oct 2011, 09:43 -
Problem with DVDShrink
By abba1961 in forum DVD RippingReplies: 3Last Post: 22nd Mar 2010, 02:52 -
SVCD2DVD when going to DVDShrink & DVDShrink Re-Author Problems in Vist
By pcandmac2006 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 23rd Jan 2009, 20:33 -
Problem with dvdshrink
By malleus in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2007, 22:03 -
Problem Starting up Beta 2.5
By mwkurt in forum SVCD2DVD & VOB2MPGReplies: 27Last Post: 14th Jun 2007, 04:42
