is it possible to use the hardware mpeg encoder on the card
wintv pvr for encoding an avi file to mpeg2 ?
maybe possible with special software.
How can it be done?
Win PVR 250 or 350. Which card do you have. Both support MPEG-2 recording only.
Nope!
Thwy will capture in mpeg2 format, but there is no way to feed back to the card an avi so it can convert it to mpeg2.
Sorry!Jose Febus -
If you have a second computer with TV out, you could feed that into your card. Should work, as it is a TV signal.
Either the 250 or 350, one, from their site has hardware MPEG1/2 capability.
It does 352X240, doesn't say 352X480 possible.
wintv pvr usb2 in linux
By diablo in forum Capturing and VCRReplies: 0Last Post: 10th Sep 2011, 09:43 -
better unit than my old wintv pvr usb2
By diablo in forum Capturing and VCRReplies: 0Last Post: 9th Sep 2011, 10:52 -
WinTV-HD software needed (not HVR, PVR, Nova, but for original PCI card)
By cybertheque in forum Capturing and VCRReplies: 4Last Post: 23rd Mar 2009, 01:21 -
WinTV Hardware Encoder Workflow?
By Armandoban in forum Authoring (DVD)Replies: 5Last Post: 23rd Sep 2008, 14:42 -
Unable to capture from camcorder with WinTV-PVR 250 card and and WinTV2000
By forestial in forum Capturing and VCRReplies: 1Last Post: 29th Dec 2007, 20:00
