I hope someone can help. Please read the scenario below:
I edited some Digital8 film in Vegas Video, rendered the completed film back to AVI then used TMPGENC to convert to MPEG2 and MPEG1 as a test. The 2gig AVI file (8 mins long) went down to 558mb in mpeg2 and 88mb in mpeg1 (both PAL). I wanted to see if I could play them back in my domestic dvd player having been burnt to CD-R.
Watching both in WMP8, the mpeg2 file (2 pass VBR encoded) was erratic. Scenes of people walking would slow down fractionally and then speed up to normal resulting in a jerky motion. I suppose this could be due to my PC (500celeron Win XP Pro 394mb ram) although DVDs normally play back OK. The mpeg1 file played back perfectly.
After burning to CD-R my domestic dvd player (Kiiro 838) picked up both MPEG files and identified them as VCD. The mpeg 2 file played back in the same erratic motion but now the sound was intermittent. The mpeg1 file played perfectly and was quite watchable.
I was hoping to create short mpeg2 files to burn to CD to play in the DVD player (I don't have a dvd burner yet). Do I take it that if you don't author with suitable DVD authoring software then thats why the sound screws up? Is that why there are vob files etc? Why would the encoding create erratic video? The original AVI is OK and so is the mpeg1 file. If one is not bothered about chapters and menus do you really need dvd authoring software? Should you just be able to playback an mpeg2 file?
Thanks in advance
Cedders
The MPEG-2 file, did you make a SVCD with it, or had a program convert it to a VCD disk.
Hello.
DV-AVI conversion to H.264 / MPEG2 - playback speed issue
By howardmg in forum Video ConversionReplies: 9Last Post: 28th Jul 2011, 00:07 -
Avi to (MPEG1, MPEG2 PS)
By kilee in forum ffmpegX general discussionReplies: 7Last Post: 27th Dec 2010, 19:39 -
From ffmpegx: SRT+AVI=MPEG2; can't playback in anything.
By sclyman in forum ffmpegX general discussionReplies: 5Last Post: 12th Jul 2009, 19:31 -
mkv2vob and avi playback problems on pc
By craig198 in forum Newbie / General discussionsReplies: 4Last Post: 14th Aug 2008, 16:53 -
DV AVI to MPEG2 Problems
By neo265 in forum Video ConversionReplies: 17Last Post: 26th Oct 2007, 03:33
