  1. age787124
    Guest
    just downloaded svcd2dvd and i can to open it.
    it comes up with. validation failure due to "xmlLoad"
    what can i do to open pog thanks
  2. When you purchased the software you received an email with the full software and an xml file attached to it. Save the xml file in the directory where you installed svcd2dvd and you are ready to go.
  3. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
