does anyone know how i can increase the volume of a svcd or vcd file? that way i don't have to increase the my speaker volume everytime
Results 1 to 14 of 14
I take it you have given up on the Gold Wave/Sound Forge solution?
Hello. -
Is there an easy way to encrease the volume of just parts of a video?
I have a camcorder recording with loud people in front but a quite person in the back. I would like to raise the one voice so it's easier to hear, but NOT the people in front or they will be screaming loud enough to blow speakers
They don't all talk at once, sort of taking turns. Far to often to cut into clips though.
I think I would need something more like selecting a section of the video, like for cutting, and then adjust that part only. -
overloaded_ide,
I recently replied to a post about the same thing your asking:
Normalising within a track
The original poster hasn't said whether he's had any success, but you might want to take a look anyway.
cheers,
mcdruid. -
Thanks.
Normalising eh, I would not have had the slightest idea what to call it, thus my inabilites with a search engine many times
But this is what I should be looking to do on a video with Loud people forground and quite in the background though? They sort of take turns talking.
Will this disort the sound though? For example I used an MP3 player once that was supposed to set all the tracks to the same volume level. It did, but the files came out all scratchy sounding and other static type noises. They worked but the quality went to heck and not really worth keeping.
Years ago I could take wave files and do this similar to cutting. Set a start and end point then add echos, change speeds, adjust volume, even reverse the selection to play backwards (never found a use for that though). Thats was about 8-10 years ago though, not even sure what program it was now. But sort of what I would like to do on this video, manually adjust certian sections. And of course I can't change the length of the clips or I'll have sync problems.
Also as you mentioned in the other post, Soundforge is probably expensive, and for now this is a one time need, not something I plan on doing alot, so I hate to spend much money for a program to work with. And this is a freebie project I am not getting paid for, just something I can learn on and be challanged! So unfortunatlely, money is an object.
overloaded_ide,
I believe SoundForge can make the volume more 'even' across the track, and the quality of its dynamic compression will probably be very good (so it won't sound too distorted).
It depends on how good your source is though, as usual.
On a budget, there is GoldWave (shareware), and Audacity (freeware) - which are both good audio editors.
I don't think they can normalise the same way SoundForge can (making the level more even), but they can both do all the other things you mention.
cheers,
mcdruid. -
i was wondering is there a way i can cut out someone talking from an audio file? there are 2 people talking at the sametime and i want to be able to cut out one person's voice so i can only hear the other
qwerty99, I would start a new topic for your question - as it's not really the same as the original one.
cheers,
mcdruid. -
To the person that wanted to raise the volume of certain people while leaving other people at their current volume level.
What you seek is volume shaping. Goldwave can do it, but it's much easier in Cool Edit. It's basically a horizontal line across your audio. You put in segment points and raise the height of the line for parts you want to increase, and lower for parts you want to decrease. You can ramp up or ramp down as well creating a fade in/out effect if you want.
Aside from that is analog sound compression. Radio stations do that to raise the volume level of their broadcast. I've never tried that before, but it could possibly help. But it will sound a little unnatural.
To the person that asked how to remove one person, I am afraid you can't unless they happen to be in different channels. Perhaps you can re-record that part if it is a home movie.
Darryl
Increasing Audio volume on AVI/DivX/Xvid with AC3 Audio
By Spacedementia87 in forum User guidesReplies: 21Last Post: 24th Dec 2021, 07:21 -
Increasing Video Volume
By edlimym in forum Newbie / General discussionsReplies: 2Last Post: 24th May 2010, 06:41 -
Increasing volume in GKnot
By Fire Foxer in forum EditingReplies: 6Last Post: 7th Aug 2009, 08:08 -
increasing volume in mp4 video
By snafubaby in forum Newbie / General discussionsReplies: 2Last Post: 27th Jan 2008, 00:05 -
increasing the volume of ac3 files
By virendra in forum AudioReplies: 4Last Post: 1st Nov 2007, 03:25
