hi, can someone tell me what i need to do backup movies...i'm new to this game and would appreciate any info ..regards theted.![]()
1.) Buy a computer with a lot of hard drive space and a DVD burner.
2.) Buy some blank media that doesn't suck (see media guide), that is also compatible with your DVD burner and your standalone DVD player.
3.) Buy DVDXCOPY XPRESS
4.) Install DVDXCOPY XPRESS
5.) Insert movie to backed up into DVD-ROM or DVD Burner.
A.) If you have both, insert movie to be copied into DVD-ROM and blank DVD into burner.
B.) If you only have a DVD burner, insert movie into DVD burner.
6. Run DVDXCOPY XPRESS.
A.) If you only have a DVD burner, remove movie and insert blankd DVD when DVDXCOPY XPRESS tells you to.
B.) If you have both a DVD burner and a DVD-ROM, click on the appropriate button at the time that DVDXCOPY XPRESS tells you to.
7.) You're done.
If you want to use free software and do trickier things, read some of the guides on this website. -
Also check out the Articles and Tools sections of this site...
https://www.videohelp.com/articles
https://www.videohelp.com/tools
You'll find a lot of information and a lot of utilities here.
Enjoy!Swift Kick In The Butt $1.00
"Everybody I know needs what I'm selling!" - Calvin -
Originally Posted by ebenton
https://www.videohelp.com/sefy/?id=ClassicalGuide.html
https://www.videohelp.com/forum/userguides/84759.php
In the first one, you dont have to do the chapter extractor stuff if you dont want to...i dont because it saves me time. Use the second one to fit it all on one cd(although you will lose some quality).
Good luck and hope this helps
