hi there,
new to all this, but here goes,got a dat file that i want to convert to mpeg so i can make a vcd,but every time i try i keep getting the message cannot locate mpeg stream. I am using vcdgear to try and convert this file but to no avail, any help on this would be most appreciated.
If it came from a VCD, then it is already in the format you need, you just need to use a VCD authoring tool to get it onto a disk and burn it.
*.DAT file is already MPEG-compliant. You can convert .DAT file to any format as regular VCD. However, you can not record .DAT file streight to VCD because it contains additional data.
If you want to burn this file to VCD, what you need to do is to multiplex your file to MPEG-1 VCD standart in MPEG Tools section of TMPGEnc.
1) Open File->MPEG Tools in TMPGEnc
2) Go to Multiplex Tab
3) Add your file.
4) Choose "MPEG-1 VideoCD in the "Type" combobox.
5) Choose output file
6) Click "Run".
VCD Karaoke (MPEG DAT file)- removing the vocals
By tsrusa2002 in forum Video ConversionReplies: 12Last Post: 22nd May 2011, 02:51 -
DAT to MPEG 1
By MI6 in forum Video ConversionReplies: 14Last Post: 8th Feb 2009, 15:01 -
convert VCD.DAT/MPEG to RMVb with dual channel audio
By newbievideohelp in forum Video ConversionReplies: 15Last Post: 6th Nov 2008, 23:42 -
How to corp a dat or mpeg file to mpeg
By onlyrasel in forum VCDEasy GeneralReplies: 1Last Post: 26th Sep 2008, 23:18 -
dat to mpeg - no sound
By goshz in forum Newbie / General discussionsReplies: 9Last Post: 22nd Jun 2007, 04:24
