  1. I need a software that can extract the sound from d dvd into a wav, wma, anything but not ac3 with d best compresion and quality, what do u suggest?
    thank you.
  2. Wow, im honnored to be asked personaly for help
    1.Rip and demux DVD using DVDDecrypter.
    2.Use TMPGEnc to convert AC3>WAV or MP3.Use "Output to file" for WAV or lame.exe for MP3.
    DVD Shrink & Nero
    My Dvd Burner Review Click Here Look For BASDSucks
  3. Originally Posted by BASDSucks
    Not bad for only being a member 3 days
    "A beginning is the time for taking the most delicate care that the balances are correct."
    - Frank Herbert, Dune
  4. He has been with me very helpful, i guess it doesn't matter how long someone has been here, right?
    I use dvd decrypter most of the time to rip the dvds, then i use dvd2avi-demux to wav- to extract the audio but i always get i big file, for an average movie i got 800mb to 1gb, but if i try to get an ac3 format it will be 5 hundred something average, wich is ok.
    The main idea is to normalize the sound to -6db with Sound forge but SF won't read ac3 so i need any other format, wav, wma, etc in order to normalize it, then with virtual dub i join both, audio and video.
    Meybe you know any software that can read ac3 and normalize it at the same time and can be save to avi or anything else.
    thank you.
