Just convert an ac3 sound using besliced and got the following errors on the log;
BeSplit v0.82 by DSPguru.
Logging start : 09/01/03 , 20:17:35.
D:\Besliced V0.2\BeSplit.exe -core( -input D:\Emule Movies\DVD-Rip's\******* **** audio.ac3 -prefix D:\Emule Movies\DVD-Rip's\******* **** audio_Fixed -fix -logfile C:\DOCUME~1\SERENR~1\LOCALS~1\Temp\BeSliced.txt -type ac3 ) -profile( BeSliced v0.2 )
[00:00:00:000] +------- BeSplit -----
[00:00:00:000] | Input : D:\Emule Movies\DVD-Rip's\******* **** audio.ac3
[00:00:00:000] | Output Prefix : D:\Emule Movies\DVD-Rip's\******* **** audio_Fixed
[00:00:00:000] +---------------------
[00:00:00:032] Stream error : Sync found after 46 bytes
[00:51:55:616] Stream error : Sync found after 981 bytes
[01:40:33:664] | Writing D:\Emule Movies\DVD-Rip's\******* **** audio_Fixed01.ac3
[01:40:33:664] +---------------------
[01:40:33:664] Operation Completed !
[00:00:46:000] <-- Process Duration
Logging ends : 09/01/03 , 20:18:21.
As you can see theres a sync problem.
Wot would be the best solution please?
Thx in advanced
TheDJ®
Results 1 to 1 of 1
MPlayer stream error
By nic3 in forum Software PlayingReplies: 0Last Post: 31st Jul 2011, 18:23 -
Problem converting from MPEG Program Stream to Transport Stream
By vivajam in forum Newbie / General discussionsReplies: 5Last Post: 24th Jan 2011, 05:40 -
VideoReDo stream error
By resloan in forum Newbie / General discussionsReplies: 2Last Post: 9th Oct 2009, 12:26 -
Error while decoding stream #0.0
By brassplyer in forum Video ConversionReplies: 0Last Post: 26th Aug 2009, 06:04 -
Some kind of error in a stream?
By Remyisme in forum Newbie / General discussionsReplies: 1Last Post: 26th Jul 2008, 10:32
