I am trying to convert from .VOB to Divx using the .VOB's IFO but whenever I start converting it only converts about 15 minutes of my video (which is a normal length movie). Also, I find DVDx to be very buggy because it always "encounters a problem and has to shut down". How can I fix these problems or where can I find a program that converts .VOB (and IFO) to DIVX?
Try the Virtual Dub mod. It accepts vobs. Hope this helps.
Hello. -
I've tried using that but if I convert the VOBs using Divx audio, the audio is always out of sync so I can't compress it and my Divx file is huge
Converting Divx to VOB - having problems.
By martinlest in forum Video ConversionReplies: 9Last Post: 6th Mar 2012, 18:23 -
App for converting .vob folders/files to DIVX or XVID?
By Newb787 in forum Newbie / General discussionsReplies: 6Last Post: 17th Jul 2011, 15:21 -
a good tool for converting avi or divx to the dvd vob format?
By extent in forum Newbie / General discussionsReplies: 7Last Post: 13th Jan 2009, 14:37 -
converting VOB to DIVX format?
By siluet in forum Newbie / General discussionsReplies: 5Last Post: 1st Oct 2008, 10:53 -
? converting vob to mpeg4 or divx for dummies
By Newbie_here in forum DVD RippingReplies: 2Last Post: 27th Jul 2007, 15:25
