Does anybody have any information on this player?
Slimline Portland pvd-1000
Target has it on sale for 35 bucks
I bought one just to check out and it plays dvd-r , vcds and mp3s
thats al I checked so far also the load times were all less than
5-7 seconds and it also has a display not like other cheap players
gonna head back to get a couple more for Christmas presents
would be nice if there is a region free/macrovision hack for it
Rodney
EDIT
Ok here some info I dug up
This Player is made in china either for or by Daewoo
even though I thought Daewoo was korean
There is no website in the manual or on the box
so I put the phone number provided in the manual in
google and it came up with Daewoo.
Daewoos website has no information on this player
what so ever.
I decided to try some of the hacks for the Daewoo machines
and the first one I tried WORKED![]()
Daewoo DVG-5200S:
FIRST PRESS "SETUP"
THEN PRESS IN ORDER
"1"
"3"
"6"
"9"
"LEFT"
"LEFT"
"LEFT"
"RIGHT"
then a new button called version will appear as the 4th topic on your set up menu. use down arrow and select by pressing play. now you can set the region code "0" for code free or each region number by pressing
the right arrow key.
just exit to the main page and your selection will be set.
WORKED LIKE A CHARM
So Far it PLAYS ALL these that I tried
DVD-R/RW , CD-R/RW , MINI_DVD , PICTURE CD , VCD , SVCD ,
AUDIO CDS and MP3
Did NOT PLAY
straight MPEGS
BOTTOM LINE:
This is a great little Player for $34.98
Rodney
Here are the specs from the box
-dvd/audio c.d./cd-r/cd-rw/mp3 playback
-down mixed 2-channel audio output
-dts digital out
-dolby digital output
-s-video output
-24 bit/ 96khz audio d/a converter
-advanced 10 bit/ 27 mhz video d/a converter
-multi angle, multi language, parental controls, etc.
-supports multilingual dialogue up to 8 tracks
-supports up to 32 languages subtitles
-6 step zoom
-smart navigation menu for mp3 playback
-selectable screen format
-full function remote control
-batteries for remote
-audio cable x 1
-video cable x 1
Rodney
Price level on (almost) new Signvideo DR-1000 and Datavideo TBC-1000
By Northpole in forum RestorationReplies: 3Last Post: 24th Jan 2011, 13:02 -
Edit, add, extract WAVE and edit file tags with new Machete 3.5
By MacheteSoft in forum Latest Video NewsReplies: 0Last Post: 23rd Dec 2009, 11:05 -
Portland PVD 1000 DVD player Universal Remote code Needed
By richco in forum DVD & Blu-ray PlayersReplies: 4Last Post: 20th Apr 2009, 17:17 -
HP Slimline computers for video editing VS full size desktop?
By vid83 in forum ComputerReplies: 3Last Post: 9th Feb 2009, 18:26 -
SLIMLINE dvd case printing
By efiste2 in forum Authoring (DVD)Replies: 12Last Post: 8th Oct 2007, 16:27
