Can someone tell me if the above drive is compatible with overburning in particular 99 min CD-R's, I'm using Nero 6 Ultra Edition and have set up Nero as per Nero themselves but when I go to overburn nothing happens it just went straight to 14% complete and froze, when I re-checked the disc after aborting the disc was still empty. Even when I've put a 99 min CD-R in the drive and I go to get disc info in Nero it says its 703 MB. I also have downloaded the latest firmware for my drive can anyone help with this problem and yes I have looked in the compatibility chart and its not there.
Will
Here ya go m8, taken from the liton website
Features :
48x ( CAV ) Record, 12x ( CLV ) Re-Write & 48x ( CAV ) Read technology
E-IDE Interface, support up to Ultra-DMA mode 2
Innovated SMART-BURN technology to automatically check media quality and set limit to burning speed to ensure successful writing sessions & data retainability ( can be turned off )
Buffer underrun error free & automatically adjust writing strategy plus running OPC to meet various burning condition ( always active )
Innovated SMART-X technology, support up to 48X speed Digital Audio Extraction ( DAE ) and high speed VCD data extraction
Supporting Plug&Play; Emergency manual eject
Supporting Fixed & Variable Packet, TAO, SAO, DAO, Raw Mode, Over-Burn
Read/Write CD, CD-R, CD-RW Disc up to 99 mins ( Orange Book Part 2 & 3 ) Easy-Tray® design for both horizontally & vertically use
Gear-Driven tray disc-loading Mechanism to Improve reliability & life, no any belt-loose belt-broken issue
VAS® ( Vibration Absorber System Mechanisam ) to reduce vibration & noise during read & write
Use Flash ROM supports internet firmware upgradeI Have Always Been Here
Toshiba Regza 37Z3030D, Toshiba HD XE1 + EP-10 ( Both Multiregioned), Samsung BD-P1500 Blu Ray. OPPO DV-983H -
Thanks alot marvel2020 how the hell did you find it on the Liteon website, I looked all over the place but found the site to be very unhelpful but once again thanks. All I need to do is work out why I can't overburn then, I'll post it in the relevant forum as I might get wrong LOL
Will -
Maybe this will help you overburn....
1.. Start up Nero and goto File/Preference's, in the window ythat will popup, change the RED MARKER setting to 99 and also uncheck the "CHECK FOR CORRECT DISC SIZE BEFORE BURNING".
2...Goto the Expert feature's TAB in the same window and ENABLE the "Enable overburing.....option", next change the Maximum CD length to 99min 59secs 00frm then just click APPLY at the bottom then OK.
Also make sure that DISC-AT-ONCE is selected before your burn.
It's in the same window as the where you set the red marker to 99mins, it's at the top.
What I've Learned so Far-LiteOn 5005
By RiteOn in forum DVD & Blu-ray RecordersReplies: 27Last Post: 14th Oct 2012, 21:58 -
LiteON 5005 weirdness
By kenmo in forum DVD & Blu-ray RecordersReplies: 53Last Post: 2nd Jun 2008, 12:05 -
change hd in liteon 5025
By DENAR in forum DVD & Blu-ray RecordersReplies: 4Last Post: 11th Sep 2007, 12:47 -
LiteOn HD-A760GX opinions.
By aqtivator in forum DVD & Blu-ray RecordersReplies: 5Last Post: 9th Jun 2007, 18:01 -
LITEON LH20A1P186 Questions
By Nubile in forum DVD & Blu-ray WritersReplies: 2Last Post: 6th May 2007, 03:27
