Everything was going well when i was burning one movie to a dvd but when i add a second movie, the audio goes out of synch.
Is this a bug, or am i doing something worng?
Thx,
Rod
are you mixing different types of audio in your movies? (ie the first movie has mp2 audio, the second has ac3).
mixing audio formats can cause problems with DVD Lab.
otherwise, dunno... I don't have problems putting multiple movies together with DVD Lab, but I make sure all my formats match...- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
No, they are exacty the same format. I use my pvr-250 capture card which is mp2.
I uninstalled and reinstalled the soft but that did not fix the problem.
I am capturing in half d1 and 224 audio.
I can use ulead moviefactory and the burns come out fine but i do not like the menus in moviefactory. -
I have played the vob directly from the hdd and the problem is there. So the problem has to be with the compile.
DVD-Lab pro menu problem
By wackman in forum Authoring (DVD)Replies: 4Last Post: 26th Aug 2008, 05:52 -
Subtitles problem in DVD-lab pro
By spyart in forum Authoring (DVD)Replies: 1Last Post: 25th Aug 2008, 16:14 -
DVD Lab Pro compilation problem
By JohnCPun in forum Authoring (DVD)Replies: 11Last Post: 8th Jan 2008, 17:31 -
Problem with DVD LAb Pro...
By GangstaRap in forum Authoring (DVD)Replies: 19Last Post: 20th Dec 2007, 14:23 -
DVD-lab pro compile problem
By Sats in forum Authoring (DVD)Replies: 8Last Post: 11th Sep 2007, 16:13
