Hey Does anyone know if its possible after ripping a DVD and shrinking it, to write it as a miniDVD with a normal cdwriter. The problem I found was that nero, clonedvd and some other proggies wouldn't want to write it as a DVD. What is logic knowing I don't have a DVDwriter. Is there a way to trick my PC so that it is possible. Or do I need some special software.
I've made some cDVDs with RecordNow Max.
I could use cDVDs for short clips but unfortunately my standalone doesn't play them.You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
you could do mini-dvd with tmpg dvd author if your project is at max the size of your cd. it works fine, I've done a lot of mini dvd's on cdrw and when I got enough movies to fit on a dvd I take the movies from the cdrw and I do a DVD with several movies on it.
Very few standalones will play miniDVd (or cDVD), my old Afreey does (and so do many of the sampo family) but thats all.. I made em for quite a while but to be honest they arnt worth the hassle. They just dont work half the time. My advice is go buy a DVD burner they are cheap as chips now..n start burning DVD-Rs.miniDVDs were only really a stop gap untill DVD burning became affordable and now it is !
Ive re-encoded some of my miniVDs to DVD format now, but of course the quality aint that great. -
I've been making miniDVD's of TV epidodes with DVD2ONE and burning with NERO. Any burning program that supports UDF/ISO will burn a miniDVD. The new Nero 6 even has a template for miniDVD. I have also burned them with NTI CDmaker.
I've made a template for tmpeg so I can put a movie on less than 700MB with quite good quality (I try to make them 620MB so i can put 7 Movie on a dvd, and 1 on a 650 MB cd with the authoring).
I use dvd2avi to make a project and encode it with tmpeg (I use the wizard to find the right tuning). (With divx I only use tmpeg)
Creating MiniDVD
By MI6 in forum Authoring (DVD)Replies: 7Last Post: 20th Nov 2008, 23:05 -
Can you capture from a MiniDVD camcorder?
By Undead Sega in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 4th Sep 2008, 21:52 -
Need advice on making dvd copies and making ISO files please.Thanks!
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 17th Jan 2008, 12:03 -
Finalize Sony MiniDVD on PC
By schematic2 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Dec 2007, 21:55 -
Using files from a MiniDVD Camcorder
By djc38510 in forum Newbie / General discussionsReplies: 1Last Post: 15th May 2007, 09:57
