OK, after going through several analog/TV capture cards, I've picked up a new All-in-Wonder 128 32meg AGP card. I'm very happy with the card.
I use it to real-time capture my VHS-C tapes of my daughter in xVCD with double the bit-rate of standard VCD. The results are good but for two things:
-The sound has constant static. The sound is clear, but in the background there is constant and consistent static. It is there when there is no intended sound from the tape.
-There is the annoying blur at the bottom of the image that is present with VHS capture.
I don't have any idea how to fix the sound. I know how to crop the image in VirtualDub, but that would then give me an avi that I would have to re-encode. Any ideas?
Results 1 to 1 of 1
"Down these mean streets a man must go who is not himself mean." - Raymond Chandler
Do capture cards clean the signal ?
By davexnet in forum Capturing and VCRReplies: 18Last Post: 29th May 2010, 20:45 -
Clean uninstall of ATI AIW 9600
By justin81 in forum Capturing and VCRReplies: 3Last Post: 23rd Dec 2009, 10:41 -
ATI 7500 AIW capture problems
By saoneg in forum Capturing and VCRReplies: 8Last Post: 6th Mar 2008, 05:11 -
Anyone using MMC with X800XL VIVO-only (no TV tuner or AIW) for capture?
By palouse in forum Capturing and VCRReplies: 4Last Post: 15th Aug 2007, 02:28 -
Capture DVD to be edited/clean?
By mlong30 in forum Capturing and VCRReplies: 13Last Post: 17th Jun 2007, 22:13
