After converting my Mjpeg Avi to Vcd via MAINCONCEPT MPEG ENCODER v1.3, the resulting video is inverted but the audio is fine. Kindly advise how to solve this. Tnx
If the encoder can frameserve from Virtual Dub, you may want to use it and its Flip Vertically filter. If your encoder can run AviSynth scripts it also has a Flip Vertical function.
Hello.
Just starting to learn Avisynth, can't open mjpeg avi and others.
By bigstusexy in forum Video ConversionReplies: 34Last Post: 11th May 2014, 17:03 -
Combining and converting AVI (MJPEG) files
By vikasa in forum Video ConversionReplies: 0Last Post: 21st Jun 2010, 13:47 -
Convert AVI to Mjpeg-II or other format
By hemang in forum Newbie / General discussionsReplies: 4Last Post: 12th Nov 2009, 08:23 -
prerendered subtitles on MP4 or MJPEG-AVI
By pokerpoker in forum SubtitleReplies: 2Last Post: 6th Sep 2009, 15:06 -
Encoding 720p MJPEG file using Mainconcept encoder --> for Streaming vid
By Mysteriouskk in forum Video ConversionReplies: 3Last Post: 25th Nov 2007, 04:39
