Can anyone tell me if you can use the latest version of VirtualDub, TMPGEnc 12a, Nero 5.5.24 or 5.5.40, Windows MMC 6.3, ATGUARD 3.22, AVIO Synth, all this Windows 2000? Any things to lookout for.
atguard 3.22 ?
maybe, depends on the "version", the FO- one may not, but depends on install. the atguard engine is now in the symantec internet firewall app. I know it wont work on win ME for sure though.
avi_io,
yes. http://www.nct.ch/multimedia/avi_io/
mmc 6.3, dont know. if your install cd came with a win2k version install that.
ztr -
The following work in 2K and XP from my personal experience:
AVI_IO
AVI Synth .3B
TMPGEnc all versions
Nero 5
As for your ATI card stuff, I am sure they have specific Windows 2000 drivers for them by now.
irc.webmaster.com port 6667 #DDR -
One thing to watch out for the WMP on Win2K. Sometimes it stays "alive" even after I closed it. It hold on to enough system resources that Nero will burn coaster discs (buffer underrun) instead of good ones.
Usually, I do a quick check on my MPEG files with WMP before I burn them with Nero.
Windows 2000 Questions
By dafoe in forum ComputerReplies: 2Last Post: 21st Dec 2007, 16:31 -
Core2 Quad with Windows 2000?
By SatStorm in forum ComputerReplies: 18Last Post: 21st Aug 2007, 18:29 -
Windows 2000 Hotfix
By MarioB in forum ComputerReplies: 13Last Post: 18th Jun 2007, 13:39 -
Windows 2000 options, if any.
By AlecWest in forum Capturing and VCRReplies: 6Last Post: 18th Jun 2007, 00:22 -
Windows 2000 question.
By AlecWest in forum ComputerReplies: 34Last Post: 1st Jun 2007, 17:54
