Hello. I made a simple guide to make VCD with Menus, Animated Thumbnails, chapters, video/image and audio backgroun, With Nero Vision Express 2. Its simple but i hope someone find it useful.
www.geocities.com/omegaweaponvcd/vcd_guide.htm
Results 1 to 12 of 12
good basic guide. you might add a step for the menu background audio. it's actually a good tool for creating menus that are pretty nice. thanks for the time and effort you put in and for sharing it. by the way, have you tried this with Roxio videopack yet?
I said I'll be done in a minute. I meant a Microsoft minute. -
ah yes...
nero vision express 2....i think it really is a great way to make excelent menus......buuuuut:
- knowing that 800 mb of (s)vcd fit on a 700 mb cd , why can't I make a svcd using nero vision?? it always its too big...even though the file is around 780 mb....
am I missing something ???
i would really like to use this program to make menus...i think it's great!
bye -
I haven't tried it to make SVCD. Neither Roxio.
sorry i will investigate.
honorarybrutha, I will add the steps for audio background, and a guide for Vcd slide show with audio background,transition effects,and animated menu
_Coaster_, i don't know exactly whats the problem because i don't make SVCD often, (cause my standalone dvd doesn't play them). But i think its because of the size of the menus. Remember that svcd uses mpg-2 format. you can use diferent video bitrates. but when you make a vcd or svcd menu, it is, in fact, just a video (is not like a dvd interactive menu). ok? the menu generated is a video file, that loops for a determinated time. so, because its a video, a mpg-2 video, ( I guess nero choose a high bitrate), depending on the duration of the menu you chose, it may be too big. And if you have a 780Mb movie, and you make a menu that plays around 1:30 minutes (not counting the loop), then it wont fit in the disc.
ok? just check the duration you set for your menus.
I hope this advise work for you.
I wish it wasnt Geocities though. My ISP has problems loading Geocities, and Tripod.
Hello. I added the step for audio background on VCD menu.
www.geocities.com/omegaweaponvcd/audiobackground.htm
and here is the guide for VCD Slide Show with Audio Background, transition effects,menu etc.
www.geocities.com/omegaweaponvcd/vcd_slideshow.htm
Is it okey to add your guides to our guides list?
Your guides will be listed on the front page for a while and then you may get too much traffic(geocities has a daily bandwidth limit). I could add them without listing them on the front page also, you have to search or list them in the guides list then. -
I put the guide in Fortunecity, because geocities Data transfer limit is very low. you can put this in the guide list. =D even you can include them in you own server if you want, just dont touch the credits :P
(Fortunecity guide deleted)
---------- fortunecity not working CHECK THIS:
http://www.angelfire.com/theforce/omegavcd/vcd_slideshow.htm
http://www.angelfire.com/theforce/omegavcd/vcd_guide.htm -
Added the vcd guide and slideshow guide
www.dvdrhelp.com
and
https://www.videohelp.com/guides?tools=&madeby=Omega+Weapon&formatconversionselect=&osse...or+List+Guides -
The fortunecity guide isnt working, i dont know why. better put the geocities address until i fix that please
or try these, i hope they work
tks tks
Main menu/chapters/audio etc all on one motion menu in Encore. Possible?
By Killer3737 in forum Authoring (Blu-ray)Replies: 10Last Post: 11th Feb 2012, 13:08 -
How to create chapter menu without thumbnails
By truongv0ky in forum Authoring (Blu-ray)Replies: 3Last Post: 4th May 2011, 15:05 -
Menu thumbnails are too big
By HMD in forum Authoring (DVD)Replies: 0Last Post: 5th Mar 2010, 05:43 -
Too large images in the Menu Thumbnails
By HMD in forum User guidesReplies: 0Last Post: 30th Jan 2010, 07:40 -
Animated thumbnails Magix Movie Edit Pro
By gayclarke in forum Newbie / General discussionsReplies: 0Last Post: 14th Aug 2007, 08:21
