I've just downloaded the trial version of DVD Lab, and I can't seem to make a DVD. Every time I try to compile the DVD, it does the menus, but not the video. I've encoded the video with TMPGEnc, using Half D1, and AC3 audio (encoded with BeSweet). I loaded the file into DVD Lab, set up the chapters/menus, but when I try to compile the DVD, it pulls up that window saying it's compiling, but it's done in about 10 seconds, and then the Video_TS folder is empty. Any idea what I'm doing wrong? I've set DVD Lab to Half D1, so it shouldn't be trying to re-encode the video... Any help would be appreciated.
Thanks![]()
"Don't try to be a great man. Just be a man, and let history make its own judgment."
Zefram Cochrane
2073 -
I think I figured out the problem - I had to de-multiplex the audio and video, and import them separately. If I do that, it seems to work, but if I let DVD Lab do it, it doesn't. Any idea why letting DVD Lab de-multiplex wouldn't work? I mean, I can de-multiplex with TMPGEnc, then import both the audio and video, but I wonder why having DVD Lab do it won't work...
Zefram Cochrane
2073 -
Check out this quick tutorial: http://www.mediachance.com/dvdlab/Help/index.htm. See if that helps.
DVD-Lab pro menu problem
By wackman in forum Authoring (DVD)Replies: 4Last Post: 26th Aug 2008, 05:52 -
Subtitles problem in DVD-lab pro
By spyart in forum Authoring (DVD)Replies: 1Last Post: 25th Aug 2008, 16:14 -
Problem DVD Rebuilder Pro: Is not a ECL for CCE SP Trial Version
By Talayero in forum DVD RippingReplies: 2Last Post: 30th May 2008, 14:25 -
DVD Lab Pro compilation problem
By JohnCPun in forum Authoring (DVD)Replies: 11Last Post: 8th Jan 2008, 17:31 -
Problem with DVD LAb Pro...
By GangstaRap in forum Authoring (DVD)Replies: 19Last Post: 20th Dec 2007, 14:23
