Can anyone tell me some settings to change to get the best out of DVD2SVCD?
Much Appreciated
syoung
Results 1 to 14 of 14
depends on a few things. For starters, which encoder are you using, what are you converting from and what are you converting to. Are you having a problem? with your current settings?
I convert mostly from DVD to CVD and use CCE 2.5, 3 pass +vaf at 2520 -300 mostly to 3 CD's. GOP is 3,4,1 and close GOP's. With my DVD burner, I use the same settings and put 2 movies on 1 DVD (CD size is ramped up to 2200 and bit rate is mentally calculated based on movie and perceived action/nonaction in film.
why dont you post your file and let somebody take a look at it. -
Hmmm...I would like to know as well.
Here's an example...
2 Hour movie, Anamorphic, 5.1 Dolby Sound, 2 Audio tracks, going to make CVD Selectable Subtitles, & Chapters.
Prefer trying to fit atleast 1 hour on 1 CD, while trying to produce maximum quality. Audio Bitrate, lets say 160 for both the Audio tracks.
Using TMPGEnc to encode, using 2 Pass VBR.
Let the analysis begin...Check out my guide on converting .OGM format to an SVCD with Selectable Subtitles and Multiple Audio tracks.
https://www.videohelp.com/forum/userguides/170944.php -
Originally Posted by macleod
Originally Posted by syoung
http://www.mpegit.net/eng_svcd.php -
Originally Posted by DivXerouS
But you should use the CCE if you want to get best out of DVD2SVCD... 8) -
Thanks for the wors of wisdom. Playing with all the suggestions and see what i get .
syoung:
If you haven't already done this I suggest you change the rate control mode to: 2 pass variable bitrate (VBR) and Motion search precision to High quality (slow). The two pass VBR will double the TMPGenc encode times, but to me it is well worth it for the boost in quality of the final product. I personally can not see any difference in quality when changing Motion search precision from High quality to Highest quality. I can see differences between High Quality and any of the other options (except Highest quality as stated above.) With just changing to these two settings, I have gotten excellant quality conversions to two SVCDs with movies as long as three hours. -
You should never close the GOPs...
MY PERSONAL SETTINGS are to close GOP's. -
Copy&paste from CCE manual:
Closing all GOPs When strong random accessibility for a stream
is demanded3, set this option, then all GOPs can be set to Closed
GOP (individual frames in a GOP do not refer to frames outside the
GOP). Since image quality slightly drops, use this function only when
absolutely necessary.
8) -
I haven't noticed an image change with keeping it open or closed. What I have noticed is that I don't get any damn errors from MF2 or other authoring softwares when I dump my CVD's (with 48mhz audio) into them to make a DVD-R.
Nothing pisses me off more than to have to re-encode an entire movie over again because I get a GOP error.
Again, for me, personally, I close GOP's. Ain't hada problem since making that change.
Sorry, I'm a thick-headed pollack, ain't gonna listen to no damn manual either. Real Men don't read instructions anyway :P :P -
BTW MF2 is not authoring program it's "authoring" program 8) DVDmaestro and Scenarist are authoring programs. 8) -
I already have it set to 2 Pass and Highest, I don't know about GOP's because I don't mess with that...
Questions regarding recording settings and compression settings
By so in forum Newbie / General discussionsReplies: 2Last Post: 6th May 2011, 07:45 -
Questions about format and settings
By joeplaysguitar in forum Newbie / General discussionsReplies: 0Last Post: 4th Jun 2010, 17:36 -
New to ffmpegX A few questions about settings ect!!
By HELLZWINDSTAFF in forum ffmpegX general discussionReplies: 5Last Post: 1st Jul 2009, 23:54 -
ac3 filter settings questions
By THX-UltraII in forum AudioReplies: 0Last Post: 11th Feb 2009, 05:32 -
some general MPC settings questions
By THX-UltraII in forum Newbie / General discussionsReplies: 1Last Post: 25th Nov 2008, 07:28
