Has anybody used this combination? www.cdrom2go.com has a good deal with BeAll discs with dvd case.
thanks!
BeAll can be had at Rima.com for .99 in packs of 100. Cases are usually available for about .19 to .35 each.
Burn Baby Burn
It's a Disk-o Inferno -
MERITLINE.COM has combo packs of BeAll DVD-R discs
For instance you can get the 1x/2x BeAll DVD-R discs with cases or the Certified 1x-4x BeAll DVD-R discs with cases.
The prices are cheaper than those at CDROM2GO.COM
Thanks for the info guys.
But has anybody used BeAll with the Sony DRK-510UL burner?
Thanks again! -
I don't have the DRX-510UL, but the DRU-500A and use the 1x - 4x BeAlls no problems. Burn them at 4x with Firmware 1.0g.
May the force be with you.
Yamaha DRX-730 HACKS
By math_ferreira in forum DVD & Blu-ray PlayersReplies: 8Last Post: 3rd Jun 2025, 07:44 -
Yamaha DRX-730; radio channels
By takefive in forum Newbie / General discussionsReplies: 1Last Post: 12th Jan 2011, 15:00 -
Importing from SONY HDR-SR1 to SONY VEGAS 8 MPEG Video resolution
By UltimateEnd in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 19th Oct 2009, 12:00 -
Crown ADVDR9000 (Apex DRX-9000 I Think...) Firmware.
By eufemia in forum DVD & Blu-ray RecordersReplies: 1Last Post: 14th Apr 2009, 11:01 -
help Drx-710ul Doesnt Recognize Dvd+r
By aqua in forum DVD & Blu-ray RecordersReplies: 3Last Post: 23rd Jun 2008, 23:57
