I hope I am in the right forum as my topic is related to Aspi drivers. I had no problems with aspi on my old system running winxp. I just built a new system with a P4 3.0 and 1 gig of PC3200 Ram. I have a Sony DVD burner. I installed aspi but the aspi I installed says it is for Win98 or win2000. Do those aspi drivers work under winxp? It shows me having aspi installed but the little sentence that says "aspi is installed and is fully operational" is grayed out and does not light up when I do a aspi check. I can rip from a dvd but I have had some problems that I have never had before. When I do an aspi check for 4 components it shows me having are versions 4.712 4.6 4.712 and 4.6. Is that ok? I am just concerned that the line saying that aspi is installed and working properly is grayed out. Thanks for any help.
Catman
uninstall the ones you've got loaded.
then d/l forceaspi (get it here or on doom9).
it installs v4.60 which works just fine under xp.
Lan Drivers
By Soixante in forum ComputerReplies: 7Last Post: 11th May 2011, 20:16 -
Help! Where Do I Get New Drivers?
By RayPaula in forum DVD & Blu-ray WritersReplies: 3Last Post: 13th Jan 2010, 10:13 -
updating drivers
By romanstopme in forum ComputerReplies: 7Last Post: 9th Oct 2008, 13:09 -
ASPI for XP x64
By HartsVideo in forum Video ConversionReplies: 12Last Post: 6th Jul 2008, 05:20 -
drivers
By Mr anderson in forum ComputerReplies: 2Last Post: 29th May 2007, 05:36
