Results 1 to 10 of 10
  1. How do i back up DVDs TO VHS please
    I have a apex DVD player and two video machines is there a way to hook them up so that the macr o protection is bypassed thanks in advance
  2. DVD to VHS is impossible..
    VHS to dvd is another story
    DVD Shrink & Nero
    My Dvd Burner Review Click Here Look For BASDSucks
  3. Sorry, edited. While it is not impossible to go from DVD to VHS, there would be a lot of work involved and the output quality will not be all that great.
    I thought I read one thing, but it was actually another. Sorry.
  4. Member Reaper88's Avatar
    May 2003
    I am not sure why you would want to do this but it is possible with a lot of work. You will need a video card with t.v output. First you would have to convert the dvd to a mpeg or avi ( divx or xvid). Hook up the output on your video card to the vcr. Play your avi or mpeg in your media palyer and make the display full screen. Hit record on the vcr. Quialty will de degraded on the vhs compaired the the orginal dvd but it will work.
    Apr 2002
    The State of Frustration
    Does not really take a lot of work. Just installing certain devices can defeat macrovision. Like this one:
    http://www.facetvideo.com
    Hello.
    This is not hard. Hook up DVD player to VCR. May require a TBC.
  7. Member Reaper88's Avatar
    May 2003
    I stand corrected. Thats an interesting piece of hardwear.
  8. I have this device http://www.facetvideo.com/ and it works well going from VHS to my DVD recorder or from a DVD player to VHS (if I wanted to do that).
    Mar 2003
    Uranus
    The TBC is for VHS output which has sloppy timing. The DVD
    player or computer will be rock solid as its timing is derived from
    a crystal.
    The only problem here would be possible Macrovision. If you dont
    want to buy a $50 Macrovision thing you could rip the DVD without
    macrovision and:
    1. Play it to the VCR if your video card has TV out
    2. Burn that to a DVDr and play it into the VCR with the DVD player
  10. lots to think about thanks for the help cheers
