Is there a way to leave out that really lame warning message?
This is all you need to do and takes 2 secs ..
1) Open IFOEDIT
2) Open movie's VIDEO_TS.IFO
3) Expand VMGM_PAT line in top half of screen and click on 'First Play PGC'
4) Scroll down till you find "1. Pre command" in bottom half of screen
5) Highlight command, right click to edit and change to something like:
"JumpSS_VMGM 1" - depending on which menu you want displayed.
6) If you want to jump straight into the movie then use command "Jump_TT 1" etc. etc.
7) Click SAVE icon to save the video_ts file
8) Preview in IFOEDIT to confirm new jump is correct
using IFOEdit to change the pre-command in the VIDEO_TS VMGM_PAT to "Jump_TT 1" will lauch Title Set 1 (assuming that your main movie lives in title set 1 i.e. VTS_01_xx).
If not change the 1 to the set you want to launch.
(thanks to wilderbeast)"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
AutoMKV hangs with message "first normalizing volume - WAIT" message :(
By Jackie78 in forum Video ConversionReplies: 1Last Post: 25th Dec 2011, 05:33 -
DVD Shrink - dvd won't open - 'invalid navigation' message...what to do...
By bahjan in forum Authoring (DVD)Replies: 7Last Post: 12th Mar 2010, 07:01 -
DVD Flick Error Message
By Dee826 in forum Video ConversionReplies: 0Last Post: 6th Nov 2008, 21:08 -
I was burning a dvd and got this message!!
By hollywoodfussell in forum Newbie / General discussionsReplies: 1Last Post: 28th Sep 2007, 23:49 -
old copy of dvd xcopy xpress
By wisconsin girl in forum DVD RippingReplies: 2Last Post: 3rd Jun 2007, 17:19
