Any one familar with in-sync Blade 2.2?
www.in-sync.com
yes - very
Concise, and to the point
A search of this site comes up empty.
Can you elaborate some please. in-sync Blade 2.2 is not listed under (Tools).
ThanksGeronimo -
its not wildly used due to instability problems and slow performance .. though spec wise .. its great ... the newer versions have taken AWAY though some of the features of earlier versions -- losing some file type imports .. though many other features have been added.
the mpeg encoder is tmpgenc by the way .. not saying thats bad - just interisting ...
the latest version has improved greatly some of the early stability issues ..
was one of the first software NLE's to handle 24p as well as HD ...
its cheap ..
what else can i say ?"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
ReddGeronimo
I don't get why Blade Runner is special - ok movie but a classic?
By yoda313 in forum Off topicReplies: 24Last Post: 28th Feb 2011, 16:36 -
Laserdisc: Blade Runner
By vhelp in forum Off topicReplies: 11Last Post: 1st Aug 2008, 23:19 -
Blade Runner Briefcase Dangerous Days (Disc 2) menu problems after shrink
By jrshull in forum DVD RippingReplies: 9Last Post: 21st Mar 2008, 12:49 -
Blade House of Chthon
By raymond_barnes in forum DVD RippingReplies: 1Last Post: 19th Sep 2007, 22:50 -
blade test
By raymond_barnes in forum TestReplies: 0Last Post: 19th Sep 2007, 21:54
