Ive been having some errors with stom record now max.
It was terminating copying my dvds, i thought maybe this was because it had problems readingthe source disk so i copied the contents of the disc to the hard drive and that works ok.
So i added the folder to be burned under the data section
And i got this error message
Data Job Terminated with errors
error 10 at sector 15066
disc writeerror command 2a Sense :03 ASC:0c ASCQ:00
From lookingat one disk it started writing some so its useless now.
Whats this mean and how do i solve it as its cost me lots of coasters which i thought this program with stop since i had no luck using nero 6
Im using pioneer ao4 with up to date firmware. The disc im using is 1x
Anyone got any ideas?
I have the original Prassi Primo which has an error code lookup in the help
03 0c 00 -> Write Error
That doesn't seem very helpful somehow
This does not help much but i use recordnow max and have had this error on a few writes posted on a few forums and done a few searches and this seems to be a common error with recordnow
whats going to happen now is someone will come along and say i have burned hundreds with recordnow and dont ever get any errors which dont help
I changed media which seemed to help but maybe the error was not going to happen again anyway.. but its worth a try -
I had similar errors on a five pack of Apple DVD-R so my solution was never to buy that media again.
Anyone here use 3DS MAX?
By Rudyard in forum ComputerReplies: 5Last Post: 25th Jul 2012, 13:53 -
Mix Max Player Help
By Empty_Space in forum Newbie / General discussionsReplies: 26Last Post: 14th Mar 2012, 18:18 -
Max Mp4 player
By drrino in forum Portable VideoReplies: 1Last Post: 28th Feb 2012, 00:04 -
Xvid.Max conversion
By hawkeye48 in forum Video ConversionReplies: 0Last Post: 26th Jun 2011, 02:48 -
What is max bitrate and max channels supported by PCM audio format?
By Bonie81 in forum Newbie / General discussionsReplies: 10Last Post: 18th May 2010, 23:35
