When i convert MPG to AVI using TMPEGenc, there is no sound , is there a special way or some sort of sound coding i use to make this work. I am using TMPEGenc because i wanna be able to batch up some encodings. I heard something like i have to use a outside sound encoder that is a plugin for TMPEGenc. Is this true? If so what is it and where can i get it ? Can someone help me please ?
If you convert a mpg to avi with TMPG, you just have to select file> output to file> avi file. Check both video and audio, chose the codecs and save or add the project to the batch encode list. There is nothing special.
You can use external mp2 and mp3 Audio encoders. Option> enviromental setting> external tool. You could encode to .mp3 seperately. But there is no need to do so, because you'll select the audio codec at the pop-up window, when you save the .avi.
Generally I do not recommend TMPG for mpg to avi conversions, there are more flexible tools. -
What do you suggest then ? I want to batch coding up though. Is there other programs that do that as well ? Also yes i did what you said i pick the video codec then picked the all different audio popups but i still dont get any sound.
Try to save a PCM uncompressed .wav. Then select the mpg as video source and the wav as audio source and add it to the batch encode list.
Well, if the batch encoding is the main issue, I don't have another suggestion at the moment. For single conversions VirtualDub might be the better choice.
How to batch convert mpg to avi
By roberta in forum Newbie / General discussionsReplies: 3Last Post: 18th Apr 2011, 17:17 -
mpg to avi result no sound
By fnietoelgazi in forum ffmpegX general discussionReplies: 12Last Post: 24th Dec 2010, 12:45 -
How Do I convert mpg or avi to vob?
By PHNeedsHelp in forum Authoring (DVD)Replies: 1Last Post: 9th Sep 2009, 14:29 -
How to convert an mpg file to avi
By spyros in forum Newbie / General discussionsReplies: 1Last Post: 9th Apr 2008, 16:02 -
Need To Convert VOB 16:9 to 4:3 AVI or MPG
By hjordan in forum Video ConversionReplies: 1Last Post: 6th Oct 2007, 22:17
